Afternoon All,
can i get a few battery recommendations and why you choose them
much appreciated
much appreciated
Some of the newer ones like C-Tek and the NoCo Genius series have modes for bringing back a very low voltage battery. (Regular or AGM type). There is no recovery for a very low voltage Lithium type battery … (10v should trigger the BMS low voltage cut-off) … I have a NoCo Genius 2 it’s called Force mode for batteries as low as 1v.The other thing is that I don't believe once a battery is that low that a tender or maintainer will help. You need an actual charger at that point.
I have had many AGM batteries go bad. They all left me with a useless battery.Lots of reports of issues with NOCO. The issue with these lithium batteries is not the battery itself, but the electronics In the battery. The BMS (battery management system) is a CPU and circuit that provides proper charging protection and regulation. These circuits go bad and leave you with a useless battery.
It's the battery. I already talked to NOCO. They were awesome to deal with. I live in Canada and purchased the battery in the USA. She asked for a copy of the receipt, a video of what it was doing and a picture of the SN on the battery. When I told her I live in Canada she said they would not request my old battery back, I just had to scratch the SN off the battery and take a picture of it. Once they saw I scratched the SN off the battery a replacement was sent out.Before you ask for a warranty replacement or refund, I suggest you try the tender on another battery like your car. Just in case it’s the bike causing it to trip.
To add to my story for not supporting Wicked Start batteries, last weekend I had the bike for a long tree l three day ride to my folks house in PA. I parked It for a week and a half. Last night I put the tender on as I planned to ride to work today. Came out this morning, pulled the tender cable, hit the power switch and absolutely nothing. Connected the tender and notice a flicker of lights. So I plugged in the tender, hit the switch again. Got a couple of lights but not a full power on. Pulled the tender cable and everything went dead. Came home after work and put my original Polaris battery in everything powered on. Measured the Wicked Start battery 4.8 VDC Vice 12.8 😠
I did measure my old battery and it was at 12.3 VDC. Put it on the tender an will check in AM. Will probably have to get a new battery. DEFINITELY WON’T be a Wicked Start!
Bingo! Buy an AGM battery that hasn’t been activated. Then follow the activation and charging instructions to the letter. In 55+ years I can’t remember running anything other than a good old Yuasa wet cell or AGM battery in my motorcycle. Up until 1990 I had to kick them over so the battery wasn’t a real issue. Activating and initial charging is a little time consuming so a lot of people are in a hurry and take short cuts. After adding electrolyte and waiting for an hour or 2 the battery will start a motorcycle but it’s no where near fully charged. And depending on riding habits may never get to a fully charged state before the batteries lost a lot of its oomph.Battery threads are becoming the new oil thread … And from now on I will only use full synthetic electrical DC Voltage in my TS111 … 😂
But seriously folks …
I think the best bang for your buck is a Bottle Supplied, AGM battery … You add the electrolyte, you charge and install it … Now you have the newest battery you can get
I believed the 500 CCA over most batteries 310. 🍭Wicked Start batteries are nothing more than a regular AGM battery, with a bunch of marketing hype.
My experience would prove otherwise 😉Renagade Wicked Start are great.
Had one in my 17 Springfield w/116bbk for over 3 years. Always fired right up even on those cold Wyoming days. Never removed from bike during winter. I'd recommend the Renegade battery & it'll be my next replacement for my new 23 Challenger.My experience would prove otherwise 😉
I too live in bitter cold Wyoming. 3 years 39k miles, Challenger Dark Horse with the OEM Yuasa still holding strong. I expect it will get me past 50 when I git me a new Pursuit about next fall lol. The OEM Yuasa lasted almost 4 years 50k miles on my ‘17 RM. I had to replace it, my fault for not checking the connection of the battery tender for 1/2 a winter. Don’t know anything about the Renegade batteries 500CCA sounds pretty impressive but is it a trade off for what’s called reserve capacity, not confused with AH capacity. In other words will the Renegade go dead quicker with the evil parasitic draw? Or if I accidentally leave my heated gear plugged into the unswitched acc. outletHad one in my 17 Springfield w/116bbk for over 3 years. Always fired right up even on those cold Wyoming days. Never removed from bike during winter. I'd recommend the Renegade battery & it'll be my next replacement for my new 23 Challenger.
If you look at reviews of Wicked Start Batteries … Folks either love them or hate them … not much in between… Several folks started out liking the battery’s but were then disappointed when the batteries died after a year and a half …
I was wondering how Renegade Wicked Start Batteries packed soooooo many CCA’s in the same size battery (Group 20, for the heavyweight bikes) … Turns out there are two ways to get more CCA’s … Get a bigger battery … more lead, more electrolyte… OR … put as many lead plates as possible in a smaller battery … BUT … the trade off is the plates are thinner.
There’s conflicting information about Thin Plate Pure Lead battery structure…
Are higher CCA’s better? | Century Batteries
Are higher CCA’s better? on the Century Batteries website.www.centurybatteries.com.au
Thin Plate Pure Lead (TPPL) batteries: Who is telling the truth?
I received the following question from Bob regarding Thin Plate Pure Lead (TPPL) batteries. I was not very familiar with them so did some research andwww.rvtravel.com
