Got this wheel chock on my trailer. Already dented the fender on the virgin attempt. By shifting g the cradle bolt up, would this prevent further fender damage? TIA
That thing looks weak and terrible. I use Condors with great success.Got this wheel chock on my trailer. Already dented the fender on the virgin attempt. By shifting g the cradle bolt up, would this prevent further fender damage? TIA View attachment 735435
18 chieftain 2021 scout 01 soft tail 2000 road king if set correct they work fineWhich model Indian is in your HF cradle? Years ago, When I measured the height of HF cradle it was 1" taller than Mc fender by at least an inch.
so didn't get HF and spent 210 for pitstop(which was next cheapest option). The PS cradle is shorter and swings below fender so no chance of damage.
Too late for me to go with HF just checking if that could have worked. It seemed at time no adjusting in the world could make cradle miss a chieftain fender.
You know, you may have a good point.@Rommel
Earlier you said you had the PS-1500 and was considering getting a wheeldock because of difficulty rocking bike out.
Before you spend cash it might help to remember for Indians (tire size 130/90-16)
there are two legal positions for rocking cradle
hole #2 from end (recommended)
and hole #3 from end (acceptable).
My guess is you are in position 2 which is the recommended position but is the hardest to rock bike out of the pitstop.
Try moving cradle pin to #3, it is still acceptable for bike but is much easier to rock bike out of cradle.
save your cash for other toys.
Here is what my HF wheel chock looks like. So far it has been good with several thousand miles of the Roadmaster in it. I use it though to keep the bike steady while I strap it down. The way I strap it I could remove the wheel chock and it still wouldn't go anywhere.As mentioned above, there are social media posts regarding the HF chock failing - here‘s a pic of one. The clamping part of the chock bent as did the upper part.
the proper setup for pit-stop is based on tire / rim size not bike make/model....
Maybe the tire size will make the difference and not pinch. Will definitely try another position if not.
By the way, anyone using the condor on a SDH? What cradle position do you have it set at?
Had this problem on my victory with condors. They're great wheel chocks but they need to be modified a little bit by cutting off the tips.I agree. I’m even considering replacing my Condors with wheel docks. If I would have been more informed, would have made that decision in the first place.
My Condors work just fine, Wheel docks just seem a better option.
I agree with this 100% after complaining on the forum about my slight difficulty backing out of my Condor (not that I was going to buy another chock). It was suggested to change my setting and it helped a lot.@Rommel
I''ll have to disagree with you as it does slide forward, as i ended up putting a large 2' x 3' rubber mat under it and it still will slide a little. But then i can't see it as i am pulling into it because of my fairing. I agree it never slides pulling out. And my Baxley ones almost never slide, but then it's the size of the bikes i use each for.Another advantage of the Wheeldock is when you need to check oil. When I'm not trailering, it's on the floor ready for me to pull in, dock the bike, and check oil with the bike completely vertical. No need for straps as it will stay in place and the Wheeldock won't slide forward as you try to enter it because there's no hump to get over. Nor will it slide back as you try to get out for the same reason. Easy in, easy out, no straps and no rockin' and rollin'.
The difference being that you are in the dock as opposed to pushing it and not being in the dock and having to try again. Going in slowly will minimize the slide.I''ll have to disagree with you as it does slide forward, as i ended up putting a large 3' x 5' rubber mat under it and it still will slide a little. But then i can't see it as i am pulling into it because of my fairing. I agree it never slides pulling out. And my Baxley ones almost never slide, but then it's the size of the bikes i use each for.
My Wheeldoc doesn't move at all. It is flat as I drive into it then I activate the lock on the back of the wheel which snugs it to the front stop.I''ll have to disagree with you as it does slide forward, as i ended up putting a large 3' x 5' rubber mat under it and it still will slide a little. But then i can't see it as i am pulling into it because of my fairing. I agree it never slides pulling out. And my Baxley ones almost never slide, but then it's the size of the bikes i use each for.
No, it's usually that i roll in too far.The difference being that you are in the dock as opposed to pushing it and not being in the dock and having to try again. Going in slowly will minimize the slide.
