Does anyone have any experience with converting the wire wheels to use tubeless tires?
Looks promising. Let me know what you find out.Read an article that sited an outfit doing a method that was considered advanced. Including some new material and heat treatment. It was an older article - 2007 I think.
I sent them an email to see if they still provide the service cause their website doesn't mention it: Wheel Works 714-530-6681 Mon-Fri 9-5 Sat 8-3
Let us all know how it works out for you.Also, I'planning on ordering an OUTES Kit. What is the rim width on out Classic & Vintage sickles?
Any others used this kit on their wire wheel Chiefs ,if so how has the installation been and the performance so far?.I am very keen to do this conversion if it's effective and reliable.Otherwise it's a big "save-up" for replacement cast wheels.I would hate to be left stranded by a puncture as getting the wheels off is not likely do-able at the side of the road and here in New Zealand we do big distances without Automobile Association close-by.What do kits cost and where are suppliers around Chicago region? Still lovin' my Chief.Doc.From the OUTEX sales sheet:
Kit consists of the following;
①round, pre-cut nipple seals
②double sided sealing tape
③protective sheet
④slip tape
⑤air valves
⑥white cotton gloves
⑦OUT☆EX sticker and hologram sticke
r⑧instruction manual,
The materials selected for this kit have been proven to be highly durable with regards heat resistance (up to 140 degrees Celsius), weather resistance and adhesion.
Tape left over after initial installation can be used for repairs such as spoke replacement.
Installation of the tubeless kit requires some basic mechanical skills and knowledge.
So we now know that this system DOES work on Harley spoked rims,I have been in touch with a dealer who sells kits but is not sure about the dimensions for the Indian rims,....???that must be one hell of a tape! Old method was an epoxy mix and you put a tape dot over each nippleso they could be adjusted without tearing the epoxy. Earlier tires were different between tubeless and tubed beads but are now interchangable. Tubeless tires are easier to repair on the road, with a tube the wheel and tire are going to have to come off, no amount of stop leak is going to help a tube if it started to tear at the puncture site.
