Hey everybody!
I have been experiencing a rather unsettling issue with my Scout, The worst incident happening today.
I was taking an on-ramp to the highway which was straight (fortunately) and there is a rough patch of asphalt left from a poor attempt to fill a pot hole. As soon as I hit the patch, I got fairly severe front end wobble, the wheel shaking side to side a good 5-6 times before I regained control. The rough spot is not that bad, I wouldn’t thing twice if I was on 4 wheels. It has happened before, as well, after hitting a ridge or rough spot at moderate speed.
I have heard nothing but bad things from the stock tires, and it is most likely the culprit but I want to see if anyone else has had this issue before dropping $500 (Canadian) on a set of Mich. Commander IIs
The tire pressure is currently set to the recommended PSI.
I am also wondering if a steering damper is a reasonable fix? but it seems odd to have to do that to a new bike no?
Thanks for your help and feedback. Hopefully I can find a resolution before I find out how much worse this can get!
