New Lighting Problem on 2014 Chieftain
3.3K views 5 replies 5 participants last post by  kirkbrews
Hi. I encountered an issue with my headlight and driving lights this weekend.
Started the 2014 Chieftain, the high beam indicator light was blinking. The driving light switch was flashing alternating green and red. Headlight and driving lights were not working. No error codes present. Shut her down and restarted, same issue. Went to breakfast, now everything is normal....
Any Ideas?
Thanks
#2 ·
The riders manual for my SF states that for the auxiliary driving lights “the switch background light flashes if a fault exists with either auxiliary light”. First the obvious: check bulbs and connectors to them. 2. Check battery cables for tightness. 3. Dunno [emoji2373]
#6 ·
Thank you all for your help.
As expected, when I went in, this was the first time my dealer had ever heard of the problem.
The recall covers all 111ci 2014 models. The pin on my ECM was burned off just like the other photos have shown. HOPEFULLY Indian has the fix-it kit in stock - not holding my breath!
The dealer did some kind of temporary fix, replaced the headlight bulb and promises to replace any more bulbs that burn out until the problem is solved.
