21 - 34 of 34 Posts
Its your money, you do whatever you want with it. I'm sure you will have a great Scout after all is done! Hell, I've put thousands into my Mustang build, and I don't regret a thing. However, I'm still on the fence on weather to modify my Scout (other than exhaust of course) or to leave it stock and have my Crotch Rocket as my mod bike. Only time will tell. Please keep us updated on your build. It is the envy of this forum!
with enough money, no kids, and no women, you can have both!
I live in the south hills of Pittsburgh, PA. The dealership (Pitt Cycles) is in the north hills of Pittsburgh, 30 miles away in Warrendale, PA. The dynamometer is located a little further north in Buttler, PA. The dyno shop is a side gig for the owner, he has a full time job. They do dynamometer pulls on the weekends.
My Bobber is from Pitt Cycles
I don’t think anyone has a problem with it and I certainly don’t. I’ve probably dropped about the same amount into upgrades and a custom paint job on my scout. My point was just that there isn’t anything magical about it lol, it just takes a lot of coin and more than more people are willing to spend. It’s also a completely different conversation than talking about the PV3/intake upgrades as those upgrades are well documented and tested.
When you start pushing the limit of what a build is capable of there are also second and third order effects, some of which may not be immediately apparent. I have a diesel duramax that is well documented to be capable of achieving 1100+ hp levels but that comes with a significant loss in longevity and durability. Alternatively I chose to go with a 700 hp build that gives me plenty for the street without sacrifices in other areas and came with a much lower price tag.
Since Mark’s bike is the first I know of to have this level of work done, the raw numbers are just the first consideration, and only time will tell how the build holds up and if the “reward” is worth the risk In the long run.
I tend to agree with dfresh, but 170 extra CCs and a hotter cam is hardly a HUGE build or undue stress on a modern engine. Its not like he is strapping a high boost turbo to it.
I also have my concerns about the durability of the engine and transmission. It didn’t take long to destroy the stock clutch.
Mike at Pitt Cycles told me the most important thing after making engine modifications is having a good tune to keep a healthy air/fuel mixture flowing to the engine. He said most bikes are tuned very lean on the air/fuel mixture spectrum to help meet ever tightening emissions. Many bikes from the factory often stumble, surge, run hot, pop and backfire on deceleration etc. According to Mike this can be very hard on the engine and annoying to the rider. After market tunes give the engine what they need and generally correct running lean issues.
I admit I was a little late to the engine tuning party. But after having Lloyd’z tune my modified Chief and Scout and my stock FTR, I am now a believer.
Believe me, I’m rooting for you and hope it all works out. Agreed on tuning, especially if you can find a skilled tuner. The difference in my Scout was night and day after CraigB tuned it for me.
Put on a pair of Big Boy Pants - no sissy's allowed, find a nice straight + lonely + smooth stretch of road ( about 1/2 mile or more) . Pull onto it, get er in 2nd gear, slowly raise the RPM and speed - level off at 4000 - 4250 rpm. At this point, snap and hold wide open throttle (WOT) until you chicken out or hit 8000 - 8300 rpm. Ease off and say hello to the bike you never knew you had - maybe go change your underwear..
Next, do the same but add a "WOT quick shift" into 3rd when at 8000 plus rpm in 2nd... Hang on until you piss your pants again ..
Enjoy the small change in your life afforded by the above..
k, so I today put on my Big Boy pants, cause I'm a grown up dammit...
(well physically, maybe not mentally, depending on who you talk to).
So, I put on Bassani slip-ons to make more noise, and they did.
But I just couldn't comprehend the whole "High-Reving V-Twin" thing, well until today.
I picked up a new set of Active Noise Cancellation ear buds, and actually pulled over right away as I was certain I had plugged the pipes somehow. I pulled one out and went HOLYCHIT.
So, I immediately realized I was running higher RPMs than before,
When I first got the Scout: 2000-2500
When I got more used to it, 2500-3000
When I realized it needed more, 3000-3500
so today, did exactly as written above, 2nd up to 4000, and then GETMESOME!
umm,
holychit...
ya, this little damn thing is a sport bike in disguise...
I don't like the vibration around the 4k, but then it clears up again...
wow, just wow...
Hey @dfresh , why don't you grace the thread with a few of those pics of your Scout ?
IMO, and AFAIK, it is truly unique and quite magical to behold..
Well I appreciate that. Unfortunately I don’t have newer pics as Ive been beholding it in the garage for months thanks to a major repair and then unexpected knee surgery. Hopefully I’ll be back in the saddle again by summer!
[emoji16]
umm,
holychit...
wow, just wow...
[emoji16]
Lol I keep saying good earplugs is the best value performance upgrade you can get!
umm,
holychit...
wow, just wow...
I think the vibration you experienced at 4,000 was the tension created between you brain and your balls trying to figure out how long you should hold throttle wide open!! (Don’t worry - You will get used to it.)
21 - 34 of 34 Posts
