On the TS111, usually 4 clean (no codes) on/off ride cycles will clear a current code to the code history file. A Scout should be the same …
Here’s the sequence if you want to clear it now…
(Should work, if not … it won’t hurt anything.)
Reset Error/Trouble Codes
Ignition Key (IK) OFF
Kill Switch (KS) OFF
Turn IK ON
Turn KS ON
Fuel pump will cycle
Turn KS OFF
Turn IK OFF
Wait 10 seconds
Repeat sequence another three (3) times ...... That’s four (4) times in total.
At the fourth (4th) time, start the bike after the fuel pump has cycled.
Run the engine for 30 seconds, then shut down normally.
Most (if not all) codes should have cleared to the historic memory.
