Bike stand recommendations please. ✌🏼
3 reading
1.4K views 51 replies 23 participants last post by  Thor Hammer
Do any of y’all have a bike stand to recommend which holds the bike level to do an oil change?
Preferably one more stable so I could wrench on my bike if needed?
I have a 2025 Sport Chief. Thanks for your help!
My odometer just hit 1901 at 19:01😎
#3 ·
That looks like that would be perfect!
Have you used this before?
Looks like I need the “wheel tie down strap” as well?
Anything else I need to add to the cart for this?
Thanks for your help? ✌🏼
#5 ·
Wheel chocks can be very handy and the type with the release pedal are amazing. (The chock I own doesn't have one of those) However, as noted in the warning on the product page, you have to pay attention to the front fender and rotor configurations on some bikes with the release pedal type. There is the potential for interference there. The OP's Sport Chief should not be a problem here but I've seen other models get damaged. My local dealer gooned up the front fender on a brand new Icon using a front wheel chock on the sales floor.
I also have a scissor lift that put under my Sport Chief. I've used it in conjunction with my HF motorcycle lift for maintenance and I use it to keep the bike standing straight up in the garage due to space constraints.
#6 ·
Wheel chocks can be very handy and the type with the release pedal are amazing. (The chock I own doesn't have one of those) However, you have to pay attention to the front fender and rotor configurations on some bikes with the release pedal type. There is the potential for interference there. The OP's Sport Chief should not be a problem here but I've seen other models get damaged. My local dealer gooned up the front fender on a brand new Icon using a front wheel chock on the sales floor.
Are you recommending that wheel dock from the link above as long as I make sure it isn’t hitting anything other than the wheel/tire?
Thanks for your expertise and insight as I definitely don’t want to mess up my ride!
#7 ·
One thing a chock won't do is elevate the bike at all so if you're looking to do maintenance you'll be laying on the floor. They also don't elevate the tires so if removing the wheels is something you think you might be doing, a chock won't help.
When it comes to doing maintenance, I'm an advocate for lifts. I really don't like working on bikes on the ground. I'm a bit spoiled since I bought my Harbor Freight 1000 lb motorcycle lift. I mostly work on sport bikes so I use rear stands that keep the bike upright but got the scissor lift as mentioned above for my Indian. It works really well for me.
The chock linked above, while expensive, looks like a solid chock. I wouldn't mind owning one but it's a bit out of my price range largely due to the other implements I have for my bike.
Note: I'll never advocate going cheap on the device that is supposed to support your very expensive motorcycle.
#15 ·
I have a CONDOR in my trailer and wouldn't change it for anything. The beauty of the WheelDock is you roll in and it locks your wheel in place. When you unlock, you just roll out, no muscling a 900+ lbs bike out of the cradle on the CONDOR. They both have their benefits and I take advantage of both.
#19 ·
Thanks for mentioning that!
Someone else on this chat mentioned liking their Condor, so was second guessing my purchase.
Will be a good week watching for deliveries because my Dean Speed sissy bar is coming too! 😁
#26 ·
Mine is a cheap(around $500)Harbor Freight hydraulic stand/lift(foot pump. I didn’t have a lot of faith in it being a $500 lift, but I’m extremely impressed with it. The build quality is more like the $1,500 stands that I had looked at before purchasing this one.
#29 ·
My odometer just hit 1901 at 19:01😎 View attachment 877471
I have one for my Pursuit. Works very well.
It will hold the bike upright without tying it down, although, probably not a bad idea to tie it down for safety.
I’ve had mine ~ 14 years. I also move it to a mount on my trailer when necessary.
Makes loading/tiedown by myself super easy.
One thing to consider when you order the size.
If you think you may ever go for a larger bike, get the larger bike and buy the shim kit to fit your current ride.
I started with a Harley Ultra Ltd and shimmed down to the Indian.
Hope this helps.
#33 ·
I have the Wheeldock and the Baxley Sportchock. The Baxley is 10 times better as far as holding the bike FIRMLY in place. Only one advantage for the Wheeldock is if you have trouble physically pulling a heavy motorcycle back out of the sport chock which cradles the front tire off the floor about an inch or so.
#39 ·
I have the Condor and love it. The WheelDock looks great, but I like being able to pull in the garage onto the dolly and then tuck the bike in a corner to maximize space.
#43 ·
I have a Wheeldock and am very pleased on the performance of the unit.
i have it mounted on my hydraulic lift and park my 2014 Vintage on it all the time without any issue.
When I take the bike in our toy hauler it is just 2 bolts to remove and 2 bolts to mount the chock in the trailer. I do use straps when I elevate the bike on the lift or transporting in the trailer.
If you contact Wheeldock they can guide you to the correct chock for your bike and tire size.
Rawhide.
#45 ·
I use a HF wheel chock and place my HF floor jack under the bike to keep everything stable. The HF wheel chock also goes in my trailer when hauling bikes. I learned a few things just now watching the lever type wheel chock video and like not having to compress my suspension when strapping the bike down.
#46 ·
I like the HF chock. It has a long stabilizer bar that also works for tie downs. In my toy hauler I just drilled 2 holes in the floor and slip a bolt in each one to keep it from sliding. When we park I just pull the bolts and slide it out of the way. I also have the HF lift which has worked great for years. Can't change oil using it though because it's in the way of the oil pan. I just do that on the side stand.
Reactions: Thor Hammer
