Has anyone wired the Zumo 590LM directly into the Chieftan? I've read the Zumo 660 threads and I've seen a couple videos for the 590 but it would be nice to hear of first hand stories for this specific GPS. Pics and videos would be most appreciated!
Were you able to find a matching plug to put on your Garmin wire? I looked at a couple of places today but couldn't find the male end.Seagull
Look under and up the left side of your fairing, there is an accessory plug hanging there that has switched power. It is a square connector with a cap. You can wire it in there. If you can't find it have your dealer point it out.
These make it an easy simple connection.
Tom
Dan,Were you able to find a matching plug to put on your Garmin wire? I looked at a couple of places today but couldn't find the male end.
I have some inline connectors similar to posi-tap, but since there already is a weatherproof connector there, I want to use it if I can.Dan,
You don't need a plug in connector for this. By using the posi-tap connector you just attach it anywhere before the connector at the plug in the fairing, there is positive and negative at the connector and it is switched so when you turn off the bike the gps doesn't stay on.
Tom
Ok, your dealer service dept should have one also. **** luck.I have some inline connectors similar to posi-tap, but since there already is a weatherproof connector there, I want to use it if I can.
I found out that it is a Delphi Weatherpack connector, GM type. I am going to try one more place this morning to get a connector. If I can't find it, I'll just put another weather tight connector on.
