1 - 5 of 5 Posts
Take yours to a good auto parts store....all heated oxygen sensors are the same basic function and electrical parameters.
The only difference is in wire lead length and connectors, and base size/configuration.
I guarantee you can find one with the same construction at a fraction of the price. Just need to splice in your wire lead and connector.
I have done this with countless bikes including exotic Italian bikes. You will find one that will work for around $40 ~ 50.
Good info. Problem we have is the bike does not have any sensors. The previous owner put in a PowerCommander V, removed the sensors, and plugged the O2 sensor holes. We are putting in a PV3 and need the oxygen sensors now.
In that case.... measure the bung thread diameter and depth to the inside of the pipe.....head to auto arts store, buy one that fits and make your own connector to the harness.
They all work the same way. You need a 4 wire heated o2 sensor.
Here's a link to a supplier for wiring harness connectors. You can find a matching connector and do it so it looks factory.
Motorcycle Connectors
1 - 5 of 5 Posts
