1 - 9 of 9 Posts
Might be hard to find, I'd do a Google search. There are some companies out there that deal in electrical connectors and terminals, I can't think of them off the top of my head also check Ebay, I saw some used wiring harnesses from our bikes you might be to purchase and remove the connectors from
I'm guessing they cracked it hooking up my quickshifter.
I found some in Cina but that can take months to get here.
I think they may be the same as the fender headress two wire connector. Search on this forum for adding a headress light. I believe someone had listed the parts they located on ebay
If this is the same connector as the headress, then this is what is needed.
"The connector is a molex 2.5 mm wire connector 2 pin. Part number Molex 52266-0211. You will also need the pins. Part number Molex 50147-8100. "
1 - 9 of 9 Posts
