1 - 18 of 18 Posts
Anyone know the best way to get the sticker off the windshield. Does goo gone work for the residue or willit damage the windshield.
I used Goo Gone without any issues. I carefully peeled it with a finger nail, I wouldn't dare use anything harder than that. Good luck, those stickers are a major pain in the butt.
Heat it with a hair dryer first. Comes off easily.
I agree with the heating I used my heat gun at lowest setting on my gas tank to peel it of, then just a little goo gone. After that i had to put several coats of wax on the spot. Didn't have any issue with the shield
Banned
I used my wife's hair dryer (carefully), and then used WD-40 on the windshield and tank stickers for the left over glue. Worked like a charm.
Banned
I can just hear that conversation. Her saying " you want to use my hair dryer for what!"
Well....I didn't tell her! :confused:
Actually, I was going to use my hair dryer type heater I use in my shop, but I was concerned that it is so much hotter than a hairdryer (just need to be cautious), and my wife suggested that I use her hair dryer.:cool:
hair dryer and WD 40 is the ticket. works great on the tank sticker too!
+1 on the wife's hair dryer and WD-40. Worked great on windshield and gas tank stickers as noted. Put on a good coat of wax to complete the fix.
Anyone know the best way to get the sticker off the windshield. Does goo gone work for the residue or willit damage the windshield.[/
I used a hair dryer to warm it up a bit in order to make it more pliable. Then carefully get a corner started and peel it off gently and evenly. DO NOT RUSH!!! I did the same way to the one on the gas tank. If you have any residue, I used spray silicone on a soft cloth to wipe it off. Use a good polish on the windshield after everything is finished. Hope this helps.
I used a cold water pressure washer on mine , after a few minutes they peel right off. No damage to windshield or any of the paint.
1 - 18 of 18 Posts
