You should be able to get a weather cap for that usb connector for when you're not using it. Also, I used that plug as a source for my radar detector and a USB charging cable - the radar detector worked fine, but the USB charging port won't work at all...I'm assuming the source circuit doesn't have enough current to charge my phone, but it does have enough to run the detector.Not sure what year your bike is.. but check this out.. this is how I wired my bike. I was able to get it from the back side without taking the front fairing off..
I already have a flash drive plugged in there with a couple hundred songs. I ride in areas that have no service so I can’t use Spotify, XM, etc.Why not use the factory USB cable in the dash?
2017 RoadmasterNot sure what year your bike is.. but check this out.. this is how I wired my bike. I was able to get it from the back side without taking the front fairing off..
10-4! Not sure what year you ride but the 2021's have the battery port right on dash, i use it to power my apple airpods (with battery tender USB stick) which enable Carplay on the Ride Command for my Iphone in the cubby. I hang the airpods on the brake line with lightning charge cable connected to the tender USB.I already have a flash drive plugged in there with a couple hundred songs. I ride in areas that have no service so I can’t use Spotify, XM, etc.
USB Splitter, Andul USB 2.0 Y Splitter Charger Cable 1 Male to 2 Female Power Cord Extension Hub Adapter for Car / Laptop / LED Etc,Navy https://a.co/d/gLD7kwf
What about something like this? Make the one in the dash compartment into a double. Assuming it can still read the songs on the mem stick would be an easy and cheap solution.
This worked great. I installed the splitter under the storage box and ran one usb into the box and the other up to the Ram mount for my iPhone.USB Splitter, Andul USB 2.0 Y Splitter Charger Cable 1 Male to 2 Female Power Cord Extension Hub Adapter for Car / Laptop / LED Etc,Navy https://a.co/d/gLD7kwf
