T
ThreeChiefs
·Guest
I see you can toggle the info center to heated grips. Do Indians take the same aftermarket heated grips as anything else? Are they pre-wired for the grips?
Does this just apply to the RM and Chieftain, or Chief as well?Yes they are prewired for heated grips and heated seat. You have a unused plug under your seat along with a empty spot on your dash for a switch. If you get a shop manual you will find some more interesting things (plugs) to be used in the future.
My new Roadmaster came with heated grips…………………..Nice!I believe the RoadMaster has got heated grips, doesn't it?
