What is this?
244 views 7 replies 4 participants last post by  JayHawk
I just changed my air filter and I found this on the ground after reassembly. What is this a cap too? Thanks.
#2 ·
That's probably your coolant cap, it on the left side of the bike. If you have long skinny fingers after taking the side cover off and also the seat disconnect the fuel hose from the tank, then lift the back of the tank up you might be able to get the cap back on.
#6 ·
To be clear, it’s the radiator cap cover. It’s to protect the tank from the metal radiator cap from what I can tell. It falls off pretty easy when you’re putting the tank back on.
