My factory warranty is about to expire and I keep getting mailers to purchase an extended warranty. Thoughts?
What you are quoting about is the protect plan, which is a service plan. It isn’t supposed to be warranty. There is an additional extended warranty that you can add for up to 5 years, in addition to the 2 year factory warranty. My dealer quoted me $1500 for the 5 year warranty. The protect plan isn’t worth getting.It is technically a service contract and not a real warranty like the one you had from the factory. Here is the fine print. Not bad, but make sure you know what you are actually buying.
Indian Motorcycle Protection Plan Purchase | Indian Motorcycle
How to purchase an extended warrantywww.indianmotorcycle.com
Here is the Fine Print
Here is what is NOT Covered:
Any of the following parts: Electrical – batteries, battery cables, fuses, audio speakers or other audio components such
as amplifies or radios, and any components used for illumination; Cosmetics & Appearance – paint, chrome, moldings,
trim, glass, upholstery, windshields, and body panels; Suspension – suspension bushings; Powertrain – fluids, filters,
hoses, exhaust muffler, silencer, catalytic converters, emissions components, spark plugs and wires, and oxygen
sensors; Driveline – brake rotors, brake pads, tires, tubes, spokes, chains, belts, primary or secondary pulleys, manual
clutch plates, discs, throw-out bearing, PVT drive clutch weights, pins, rollers, bushings, and springs.
If that’s the case that’s pretty shady. My dealer explained each in great detail.Keep in mind many dealers sell the Protection Plan as "The Extended Warranty"
No true, any warranty you buy starts AFTER your original OEM. The paperwork specifically says so.Read carefully it goes onto your original 2 year warranty say you purchased a 3 year extension well two years of it is already gone by the regular warranty so you get one extra year
