41 - 60 of 75 Posts
Sweet. I’ll mod as needed thanks for the heads up on it. Looks great man. I tried my best to get her to just use the factory sissy bar I bought. She sat on a friends RG with tour pack and wanted one
Unfortunately, that sells a lot of trunks!
I've got that same trunk on my C.D.H. and it fits my helmet without any modification. Strange
What size is your helmet. I have all 3/4 helmets, I have 3 of them and none of them would fit with out modification. A 1/2 size helmet would have fit.
lutch. That emblem on the sides of your tank is badd freakin ass. Where’s those come from?
The Ruthless mount is nice and all but is to wide for the bottom contours of the box. Therefore I had to use the mounting plate that actually goes inside the box, between the box bottom and the Ruthless mount. It actually raises the box an additional 5/8”. I simply used large washers on the inside of the box instead os the mounting plate.
I think all these plastic HD boxes are pretty much the same. They all seem to have the same dimensions with differing hardware. I bought the ProPad set up and it came with their rack. After my first trip with the trunk I thought I would try it out on my VicBaggers rack. I found the rack just a little too wide for the recessed section of my trunk. The Ruthless has the same issue. My trunk did not come come with a mounting plate. I added a piece inside my trunk to make it all more solid.
This is the inside of my trunk before I added the SS plate. The four reinforced holes on the bottom line up with the slots in the ProPad rack.
646828
This is the SS plate I added.
646831
This plate works for what I intended, but will not help any with installing my trunk on the other racks. What type of mounting plate came with your trunk? I have seen these HD mounting plates and wondered if that was what was needed.
646832
The plate that came with my trunk looks just like the SS one you show above. I had to put this under the trunk since the Rurhless Designs was to wide for the bottom contours of the trunk.
I got the pack from Motea and rack from ruthless. I made 2 spacer blocks from pvc, cut them down to 9/16” on table saw and used them to take up the gap under the tour pack/rack. Sprayed with trim adhesive to hold them in place and set bolts in it to stay lined up for a few minutes until it set. Then I used the big metal plate inside of trunk
647666
My ruby red metallic is coming today from vic baggers, been waiting since April, Indian finally released that paint color
Concerning the actual mount that attaches to the bike, does yours have any "play/give" to it? Like I can grab my trunk and pull up on it, and it lifts a bit off of the spools. So every bump in the road I can hear the trunk rattling behind me a bit, and it's annoying. My mount is from 2x2 cycles.
Ordered mine today will see what I think. Cant do the price for the full tour pack from Indian. It's a great trunk had it on my Roadmaster.
41 - 60 of 75 Posts
