1 - 7 of 7 Posts
Has there been anyone that has made a video on changing the valve springs? Wandering if lowering the engine or lifting up the back bone would be easiest
Put the back tire on a 4x4 block so you can lower the motor far enough to do everything. Get a compression tester hose to pump air into the cylinder to keep the valves from falling while you have the spring off
Might want to add using the new nylon rope trick to hold up the valve when working on the valve spring as a good cheap option. A wooden block under the back tire helped me. Also, label & baggie everything. If you do go the compressed air route, use anti-seize on the threads.
These 3 threads were really helpful, might want to check these out 1st if you haven't seen them.
Valve Spring ?'s
LLoydz valve installation tools-any good?
An analysis of TS111 valve springs and related valve train STUFF!!!
1 - 7 of 7 Posts
