1 - 8 of 8 Posts
2020 Roadmaster 116 stage 2
2020 Roadmaster people, can you play music from a usb plugged into the cord on glove box? Used to be able to on the 2018, but wont on the 2020???
German Rider
MB ? I think, you meant GB.
Cu,
Sven
Yes, but don't exceed a 128mb stick. In fact, 8 MB is the standard for that. Anymore and it may not be able to address the stick.
That is on a 2020 model?
You also have to make sure that your USB drive is formatted in either exFat or Fat32 before copying your music on to the USB drive. NTFS format will not work on the 2020's
Is this different from the 2018 models? The reason I ask is the usb drive that worked on my 2018 does not work with the 2020. Both Roadmasters.
1 - 8 of 8 Posts
