We offer "Do It Yourself" quick release mounting brackets for all of the Indian bikes. This has become a popular item so we made a few changes to make it easier. We offer brackets for both sizes of fender spools and two sizes of flat plates. (If you are using a large side hinged trunk you will want the larger plate. The plate is 1/4" ABS and you can drill holes to secure your own trunks as desired. Now we have been finding that people have different tastes as to how far back the trunk should be mounted. So now the brackets and plates come with numerous holes predrilled so you can move it forward or back. In some cases if you mount it far back you will need to drill a couple holes. It has guides where to drill. (NOTE: The antennae brackets are not included and not needed.) www.IndianAftermarket.com Then select your bike under PRODUCTS
