1 - 15 of 15 Posts
Can someone point me to an error code guide or perhaps tell me what this means?
Thanks in advance!
0 598
2
2016 Springfield 111
Discussion Starter #7
Indian Diagnostics App, just installed it
Thank you gentlemen
The clutch switch sometimes gums up with road grime. If that's what is causing the error code it's fairly easy to spray it with WD40 to clean out the crud.
Discussion Starter #11
Thank you for the hat trick Dr. Will do it!
Ah ok - there appears to be no equivalent app in the iPhone universe. Indian Ride Command doesn’t show engine codes. Maybe someone knows if there is?
1 - 15 of 15 Posts
