1 - 20 of 29 Posts
Anyone upgraded or modified the turn signals?
I am working on blocking out my 2015 scout. I ordered the kuryakyn torpedoturn signals, but i don't think they will match up too the rubber base on the oem mounts.
Thoughts? Ideas?
You could get a set of fork mounted signals. Cant tell they are there until you hit the switch. So essentially its a blacked out look since they blend in. About $80 or so.
I have to remember. Its been a while and i dont remember the size. Revzilla had them i think
I went with the Joker Machine Dual Rat Eye LED Indicators for front and back.
Joker Machine LED Dual Rat Eye Rear Turn Signals
For the rear, I used these Joker Machine turn signal adapter plates to mount to existing license plate bracket. No modifications to the stock bracket required.
Joker Machine Turn Signal / Marker Light Adapter Plates For Indian Scout 2015-2017
For the front, I modified the stock fork brackets / mounts and used the same ^ turn signal adapter plates. They just required a little modification to fit the stock fork clamps / brackets.
I went with the Joker Machine Dual Rat Eye LED Indicators.
For the front, I just modified the stock fork brackets / mounts.
For the rear, I used the Joker Machine turn signal adapter plates to mount to existing license plate bracket.
I like the rear option you have. Ive been looking for something that didnt alter the bike in amy major way but was low profile
What lights did you end up with back there?
I used the same lights front and back. The Joker Machine Dual Rat Eyes. I really liked that they were bright, aesthetically pleasing and still remained fairly low-profile. I can snap a picture when I get home later
(EDIT): I edited my earlier post to clarify. Sorry for the confusion.
Discussion Starter #20
Cool Thx
1 - 20 of 29 Posts
