1 - 3 of 3 Posts
I have a 2018 Roadmaster with a little over 10000 miles on it. Went to the dealer for the recall and they also fixed the clutch switch.
Now my problem is about a week later I took it for a short run( 100 miles) and the controls on the left side stopped working. Turn signals, radio and screen changer would not work. Bike still ran good and I wasn't far from home so home I went. Shut it down and started it back up and everything worked fine. Has this happened to anyone else? What should I check?
Check the connectors behind the headlight where the wires from the bars plug in. It is possible (although I don't see why) that the service tech disconnected them in the process of replacing the switch and did not fully seat them back together.
1 - 3 of 3 Posts
