Is there any way to test the grip itself? I know how to shoot through the wiring harness to check for shorted or open wires, just haven't had the time to do it yet, and I don't want to drop $123 for a new grip on Cheap Cycle Parts if that is not going to solve the problem.
I installed KST Apache bars last November, with Rox Risers. Went for a ride today after installing the battery, and the R/H grip is not heating up. Left hand grip heats up just fine, the console switch works properly to change the heat level and shut the grips off, and the pop-up on the Ride Command screen works properly, as does the display page with the heat level on it. I also swapped the connectors behind the headlight, and the left grip still heated up normally when connected to the right hand grip connector, which leads be to believe that the wires are all good.
At this point, I think there is something wrong with the grip itself. I pulled the grip off and verified that it was connected, put everything back together, but it still did not work.
