1 - 4 of 4 Posts
2018 Indian Chieftain (Tanto) Steel Gray
I am sure this has been asked before. I have a 2018 base Chieftain. How do I find out if I have TPMS?When I look in the ride command I see the TPMS learn screen. I purchase one of the tools to sinc with the bike(VXDAS) but I couldn't get it to work. Also while on the subject what is the function of the TPMS erase? Thanks
I am sure this has been asked before. I have a 2018 base Chieftain. How do I find out if I have TPMS?When I look in the ride command I see the TPMS learn screen. I purchase one of the tools to sinc with the bike but I couldn't get it to work. Also while on the subject what is the function of the TPMS erase? Thanks
I use the Bosch tool, has to be very close to sensor in wheel 180 degrees from valve stem. TPMS erase used when changing sensors.
Sent from my XT1650 using Tapatalk
Can you add it just by installing the sensors into the tires?
1 - 4 of 4 Posts
