1 - 5 of 5 Posts
I think I have seen it before.
Can't find it.
Or maybe I am mistaken...
But, is there a way in the Ride Command settings screens to select a different PSI value for the TPMS alarms?
Like, if I want my alarm to trigger at 36psi rather than 40psi.
There is not.
It triggers when tire pressure is low.
Spec for rear is 41psi.
So when your tire is at 40, your tire is low causing the notice bar to come on
Can't find it.
There is not, and why would you want to? These values are locked down for safety reasons.
Early joiner
Can't find it.
You & the TPMS must allow for an increase of 4-6 psi ‘hot’ reading.
1 - 5 of 5 Posts
