So I bought a totaled Scout Bobber with 987 miles on it from a Copart salvage auction. The main damage on the bike is broken frame parts, but there are some other miscellaneous pieces I need. The engine got out of it unharmed and should theoretically run (It supposedly started and ran when I bought it).
I've taken pretty much all the broken parts off so now I know what I need, I'm hoping you guys might know where to find these parts or have some lying around, I'm trying to save as much money as possible since I'm already in a pretty decent amount of $$ for a salvage bike.
The parts I need are as follows (in no particular order, with official part number next to them):
Front frame 5139652-626
Front engine mounting bolts (2) 7520029
Front fork (pretty much the whole thing) 1824582-266 and 1824583-266
Front brake rotor 1912076
Front axel 5138767
Front triple clamp 5140033-658
Left and right frame backbones 5633874-266 and 5633875-266
Radiator 1240902
Left side upper radiator mount 5415296
Radiator mounting bracket 1020996
Fan 2412703
Coolant hose 45cm 8450120-45
Front tank isolator (1) 5414852
Clutch cable 7082318
License plate bracket (side) 5633817
Right side headlight shroud bracket 5633775-463
There are also some slightly damaged, but still usable parts:
-Front fender (dented and scratched) 1021869-601
-Radiator Guard (scratched a little on the bottom) 5454506
-Exhaust Heat shields/pipes (slight scratches)
-Tank (little dents and scratches)
-Mirrors (scratched) 2636496-468
^If anyone has small amounts of paint that I could use to touch up these parts please let me know
Also, some advice on getting the bike operational again:
Can/should I assume the previous owner did a 500 mile oil change/service?
I will keep this thread updated with info and pictures, it looks like I can only attach 10 images at a time.
Thanks,
Jake
Front axel 5138767
Radiator 1240902
Fan 2412703
- matte black frame paint
- the gloss black on other parts of the bike
- Star Silver Smoke for the fender/tank
- matte black for the exhaust and heat shield
Thanks,
Jake
