1 - 9 of 9 Posts
So I'm running freedom duals with zombie baffles on my 17 Chief DH. Needless to say, even after stage 2 cams and a tune from Craig B, the mid range torque sucks. I found a temporary solution at the recommendation of someone with the same setup. I was reluctant but said what the hell, let's give it a shot. This little fix actually made a noticeable difference and cost be about $3.00. For anyone with the same issue, I highly recommend this.
Yeah we had the big city thunder baffles on Vic Hammer
They helped rather then running full open
All it had was a washer welded inside .
Pulses would hit the washer and create a little back pressure improving the lower end
That's an interesting way to create some back pressure. I won't delete my CAT for that reason. There is somebody out there that take out the cat on the stock header and then welds back-in some metal that is supposed to help the back pressure and eliminate that "tinny" sound you get without the CAT.
Let us know how it holds up over time.
Reactions: Joe Texas
I recently did what I thought I'd never do which is go back from the TAB zombies to the Rineharts so I can have a little bit more torque. I wish I saw this post first, wouldve tried it.
yep ... another variant of "lollipos".
There is lots of info out there ... google "thunder torque inserts lollipops"
I did not know they sold them. Will look into. Thanks.
Just know that if you have regular Rinehart baffles they are not a true 2.5 baffle they bottle neck down to a 2.3 inch then open up to a 2.5 or so where the fit on the head pipe and at the end where the caps are.
1 - 9 of 9 Posts
