I just thought I would tell everyone that i have purchased this tool to reset the tire pressure sensor if you lose connection. I have tested it and it works. TPMS Activation Tool EL-50448 Relearn Reset.
Amazon.com: Kent-Moore EL-50448 TPMS Tire Pressure Monitor Sensor Activation Tool: Automotive
I know there was a question on here as to if this worked or not. It does. You have to mark the spot on your tire 180 around the other side of the rim on the same side as the valve stem. You must hold the tool there for at least 10 seconds in my tests. You must have access to the front and rear within 15 seconds or the indian clears looking for it in a timely manner. I little bit of a pain to get them in the right location but it does work and it is the right tool since I am 180 miles from a dealer.
