1 - 10 of 10 Posts
But, that come with the grip welded or only the throttle tube? Because I only need the last one.
What kind of throttle tube I need for the Scout? In case I need to look for a replacement out of Indian dealer.
Thanks, guys!!!
Avon grips has wonderful ones that are fit for the Indian. I had an easy job installing the throttle side.
We had to grind the grip off the factory throttle sleeve here at Flat Out Motorsports (Indianapolis), We are trying the AVON grip and sleeve, it appears is the best solution so far. The factory grip is nearly impossible to get off the factory sleeve.
As previously said, the Avon gels are great. Very comfortable and easy to install.
1 - 10 of 10 Posts
