Howdy folks.
Something happened with my bike ('16 Roadmaster) recently that I though it would be something interesting to share with you. I´ll tell the whole story just to contextualize (the solution is at the end).
My bike is on the third FOB so far. The first replacement was made by the bike´s first owner, so I got the bike with two FOBs. The problem with the first FOB was that it wasn´t holding its battery charge (put on a new CR2032 and it lasted for only two weeks - like it wasn´t "turning off" when away from the bike). The second, I accidentally damaged when I replaced its battery (broke the soldering on the battery connector). Then I got a new FOB and had it programmed at the nearest Indian authorized service center, which is about 150mi from where I live.
This was accomplished about two months ago, and it was working just fine so far. Then, another day, I went on a small ride , went back home and when I tried to start the bike the next day, the FOB key wasn´t being recognized by the bike anymore.
At first, I thought on the FOB key battery (as the part was probably on stock for quite some time and the battery might have degraded). It didn´t solve the problem, in fact, testing the FOB battery on the multimeter the voltage was just about right.
Totally p***** off, thinking I´d had to lose another whole day to go to the nearest dealer to reprogram the FOB (a job that costed me 100 USD, plus gas and toll booths on the way to the dealer) ... well... been riding the bike using the PIN to start it for the last three weeks. I´m kinda used to it, but I was enraged that the bike was on its third FOB key and going to the fourth (for which I´d probably have to wait some 60 days to delivery as Brazilian Polaris representatives have almost nothing in local warehouses).
Yesterday (still not the solution, I´m just putting into context), I thought about the FOB antenna receiver (the small rectangular box that´s near the VCM). Well... my thoughts were... the underside of my seat is really cramped up in wiring (illuminator modules and other stuff), and as during the last ride where the FOB was still working, I did take some major bumps. I wonder if maybe the seat wasn´t properly positioned and might have damaged the FOB antenna wiring.
So, today, I took out the seat to check the wiring. It was in totally perfect order.
Then, EUREKA! I remembered about the horn issues (VCM wrongly accusing shorted horn) I had a few months ago (after taking out the Buffalo horn - due to malfunction - and putting the stock back on). What I did back then? I did reset the system. I disconnected the battery and the horn started working again.
So, I thought: I wonder if doing the same will "reboot" the ECM (afterall, the FOB key code is programmed into it).
Taking out the seat, the first thing I remembered was about the risk on frying the VCM when disconnecting the battery. Then, what I did: I simply unplugged the three connectors that go into the bike´s VCM. I didn´t even bother to disconnect the battery, I only disconnected the VCM from the system (it might be wise to do it before messing with the battery, instead of risking a short circuit!) and let the bike "rest" for two minutes.
Plugged the VCM back in and then... voilà!!!! My FOB key is now working perfectly again.
So, in the event of your FOB key is no longer being recognized by the bike (even with a good battery), BEFORE spending good money taking the bike to a shop or dealer, simply disconnect the VCM and let it rest for a few minutes (two minutes is enough).
Edit: Just pull out the VCM fuse as suggested by Demolition Man below. No need to take the seat out.
It might just do the trick for you, as it did for me.
