1 - 8 of 8 Posts
I've noticed that every 5000 miles or so, my '18 Scout starts to idle roughly. Not missing completely, but those 'light' fires you can hear and feel. What I've done as a correction (hopefully) is to run about 10 gallons of Techron treated fuel through the bike, just before I change oil and that has cleared it up both times.
I learned the procedure from BMW(cars) where they recommend cleaning the fuel system before each oil change, with Techron. The reason to do it before an oil change is the possibility for oil contamination. I run non-ethanol fuel almost exclusively, and it may not have all of the detergent additives found in premium fuels.
Any thoughts?
Sea Foam usually does the trick too,atleast that's what I was using and it worked on both,my vehicles,and the fleet or 100 vehicles I used to service when I was working.
In my vehicles, if I have a choice I fill up at Chevron. The fuel is supposed to have techron added. How much is actually added I have no idea. Every once in a while I add a bottle of techron to my trucks. I haven't added any additional techron to my bike. I have over 10,000 miles on my bike without any rough idling issues. Thanks for bringing up the topic.
Phil
Phil
I came across this when looking up what Techron does.
Techron is a patented fuel additive developed by the Chevron Corporation, usually consisting of gasoline mixed with 400 ppm of polyetheramine. With the introduction of Techron, Chevron gasolines became designated as meeting Top Tier standards for fuel cleanliness.
I buy my fuel at Costco which carries the Top Tier designation. How much premium I get after the Subaru in front of me leaves regular in the twenty foot fueling hose is another conversation.
I also add a little Yamaha Ring Free every few tank fills.
Discussion Starter #7
I'm looking up Yamaha Ring Free now...
Reactions: MilwDave
I’ve had the bad gas issues with my vintage and yes you can tell. If there is bad gas I add sea foam and it always helps.
1 - 8 of 8 Posts
