1 - 3 of 3 Posts
AE329350-721A-4D48-A1D5-4E96CCAB10E1.jpeg 3047727F-17E2-4A9F-B07F-CA354B48128E.jpeg 1B9D37F2-3917-442A-9DF6-862F86B9BB3C.jpeg 10B107BD-EBDA-41B0-AB97-1D04761932AD.jpeg 65A3CB8E-D1FA-4A23-AC4B-BDA79935583D.jpeg AD4F9B82-B901-4E4A-A965-FF167A2B6EDD.jpeg 88253908-83ED-4E99-92BC-2969FE23F38F.jpeg 54164424-F54B-4369-8C63-FC3B4F1E4E5D.jpeg 230988D0-FF7F-4886-BDAC-69EBAA386EE4.jpeg I decided to add a highway bar to my Chief Classic . Seeing the Kuryakyn toe pegs, I thought it was time. And who knows when the bike may tip, although it has not to date. After looking I decided on the Chrome TCMT 1-1/4” unit from eBay for $137 with free shipping. The cheapest Genuine Indian was $300 with shipping and the dealer wanted over $400. I have to say it is real nice. It was boxed and packaged perfectly. The chrome plating is as good or better than on my Indian OEM Scout bars and it fit perfectly, everything lined up. It’s rugged too. You do have to buy the correct bolts. Theirs are trash and the wrong thread pitch (bad for an aluminum frame). Actual Install was about 20 minutes and everything was in perfect alignment. I spent more time waxing it and jacking up the bike than wrenching it on. If you buy one, get 2-stainless m8x1.25x20 for the top and 2-m10x1.5x25 for the bottom. Have a helper since you do have to remove the right floorboard to get at the bolt and having someone hold it makes it easy. The bolts were less than $2.00 each. I sprayed the drain holes with a hearty WD40 coat to quell any internal corrosion. The bar was on EBay from Motomart11 as the seller. Here is a link to all the photos. https://photos.app.goo.gl/VGJAVbKATaXtniUB9. I opened the box at 5:30 PM and was complete by 6:30 .
I picked up the XMT-MOTO Mustache Highway bars for $176 off Amazon and they came in the same TCMT box and wrapping. Almost identical it looks like except the Mustache profile. Same with the bolts and speed of install. I tend to always pop a little blue lock tight on any bolts I pull off and put back on or put on new unless something else is needed. Ever since I almost lost a clutch and footpeg assembly on the highway during a long ride. Good write-up!
1 - 3 of 3 Posts
