1 - 4 of 4 Posts
well they come pre-wired for a heated seat... so if you can rig it up like that there is a power source.. I don't know if you would need an on/off switch if it's powered when the bike is off or not... also you can check the schematics to see where they plug the trunk into...
The switched power connector under the seat has a black ground wire and gray/*********** wire. Depending on the lights you want to connect, this might be the best one to use.
If you splice into an existing lighting circuit the canbus might complain. A lot of the lighting circuits are checked for expected current draw and adding extra lights can upset the canbus. Some aftermarket lights are designed for adding to a canbus system but there are others that don't play well.
1 - 4 of 4 Posts
