I've been delaying posting this because no doubt someone here will find a way to blame me for this.
a couple of weeks ago I noticed the surging throttle is back. I wasn't sure if I was imagining it so wanted to get out and test it in different t conditions and see what was happening. it also seems different to what was happening before.
on the weekend I Rode for about an hour. I noticed it the most in 2-4th gear, between about 2800rpm and 4800rpm. the surging was quite noticeable and when it happened I looked down at the speedo and could see my speed varying up and down by as much as 4kph. might not sound much but when you're doing 80 it is. and when you're riding at 40 through roadworks and it does it, people all stare at you.
it seemed to smooth out and almost go away at 5000rpm. it also didn't seem to be happening as much in 5th and 6th but having said that I wasn't in those gears much as I was in the twisties.
today I plugged in my pv3 and watched it as I changed the grip position. last time it bounced around like hell. this time it seemed steady. other than it showing two different and odd tps numbers when the grip was all the way closed it was pretty steady
so I need to call my dealer cause its getting worse and is nearly unridable again. the problem is I'm not sure if its a second throttle thats failed, or an issue with the tune, or even a slipping clutch??
any ideas or suggestions before I call them?
video of the pv3 here
