1 - 13 of 13 Posts
I’m afraid this is going to be vague, but I’ve recently started feeling extra added engine vibration above about 2500rpm. I can’t recall exactly where now and it’s quite cold to ride, but I kept forgetting to talk about it. If it vibrates normally like o—o—o—o—o, now it’s something like o-o-o-o-o-o once I hit a specific engine speed. At idle it’s fine. I thought it was maybe a bad tank of gas at one point, but it’s been several tanks since and its still doing it.
I will check my oil level when I get home. I’m worried it’s a symptom of a more expensive issue. Any thoughts?
Check the engine mounts.
Unless it’s super loud it sounds normal to me. The engine vibrates at a certain way, but other things also do. like any two closely related waves, they can create interference effects. Mine does is around 3000 RPMs or so. It’s more noticeable if the oil is slightly low.
What gear are you in at 2500. If you sre in top gear and you throttle hard it could be that you are lugging it. That can cause a very noisy engine untill you get the engine rpms up higher.Just a thought.
1 - 13 of 13 Posts
