Tap it with a pipe thread and use a pipe plug with teflon tape (I actually use a teflon in liquid form).
Use grease on your tap to collect small peices of metal.
This has been a problem with several Chiefs, including mine at the first oil change. I used an over-size self-tapping drain plug from the auto parts store. I had a lathe available so I turned the end of the plug down flat after I'd tapped the threads. Be careful not to over-tighten the new plug! Snug and no more.Started to do the 25K oil change yesterday, first time for me on this bike. I discovered that the tech that had done the last one tightened the outside drain plug so tight he stripped it. What is necessary to fix this and how big of a job is it?
Where did you buy the Time-Serts Kit from? Please let me know and thank you so much for the info.Mine striped out on the 5000 mile oil change. I bought a Time-Sert kit for the repair. TIme-Serts are similar to a helicoil but instead of being a spring insert, they are a solid steel insert. Makes for an extremely solid repair. The kit cost me around $125.00 which is a pretty expensive repair but I didn't feel like hassling w/ the dealer and I wanted the confidence knowing that the repair was done right.
I had to do the same repair, here's the kit you'll want: https://www.amazon.com/gp/product/B003SER3PA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1Where did you buy the Time-Serts Kit from? Please let me know and thank you so much for the info.
I found I have to use two copper crush washers to keep it from leaking. I put on two washers, torque to spec and I am good to go.I had to do the same repair, here's the kit you'll want: https://www.amazon.com/gp/product/B003SER3PA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Be careful when you do it, I had my dealer do mine and they put it in a little off kilter....had a leak from the plug until I figured out how to make a gasket to fill in the gap.
Never thought of that and I spent a lot of time pondering how to stop the leak....thanks for posting that, I'll give that a shot next time.I found I have to use two copper crush washers to keep it from leaking. I put on two washers, torque to spec and I am good to go.
Did it work is this holding no leaks?Mine striped out on the 5000 mile oil change. I bought a Time-Sert kit for the repair. TIme-Serts are similar to a helicoil but instead of being a spring insert, they are a solid steel insert. Makes for an extremely solid repair. The kit cost me around $125.00 which is a pretty expensive repair but I didn't feel like hassling w/ the dealer and I wanted the confidence knowing that the repair was done right.
