1 - 11 of 11 Posts
I came off of a 2006 Roadliner with Hydraulic Clutch and have been trying to decide weather the CLUNK I feel during shifting is just inherent with a cable clutch or...... Do I have an issue.
I've chalked it to this must be how these bikes feel. Not only do I feel it in the shifter, but I also feel it in the clutch handle.
I've been pretty mellow on the bike for the most part, but tonight I decided to try out SPORT mode and put the screws to this machine.
At about 80 in 4th gear shifting to 5th, then going for 6th I swear the bike went back into 4th. So much so that I actually had to shift back through 5th & 6th again.
Anyone else having any kind of issues with Clutch or Shifting?
Is it supposed have such a CLUNK feel and sound?
I've got 2900 miles on the BEAST! :cool:
Feedback is appreciated.
With cable clutches, they need to be adjusted properly. Most likely your symptoms sound like the clutch free play is too much. Usually the first 500-1500 miles the cable will stretch quite a bit.
The clunking is that you are not dis-engaging the clutch fully because there is too much free play in the cable. Your manual will show you how to do it. Very easy.
On another note. The free play in most of the Indian models is very little. I don't know what the challenger is, but most of the Indians the clutch free play is slightly thinner than a credit card.
I've had to adjust my clutch a couple times to get it right. From the factory, the clutch was catching way too late and made for odd/funky shift feel.....but once I adjusted to the specs above, the bike runs like a dream. Finding neutral is easy and no clunking. I like how the slipper clutch works.....so far. Deactivate your traction control and have some fun.....as that's where it starts!!!!
.0196-.059"
I'll have the dealer check it, as I don't have feeler gages to do it accurately myself.
When moving down the road it doesn't take much clutch pull to disengage & watch the RPM's rev.
Thanks guys!
.0196-.059"
Thanks guys!
A credit card is about the right thickness if you want to do a quick check.
Discussion Starter · #10 ·
Thanks HyeHog
1 - 11 of 11 Posts
