1 - 11 of 11 Posts
Is there a trick to get the stock pegs off while keeping the mounting brackets on the bike? It looks like a little spring clip on it but I can't seem to snag it to pull it off.
I didn't answer your question, but I thought I'd post the manual page anyway, if it helps.
593205
I'm 58. I have to use a hook and peepers, not a pick a readers.
Discussion Starter #9
As an FYI for posterity's sake, the easiest way I found to do it is to find one of the overlapping ends of the spring and then slip the pointy end of the pick (or hook!) parallel to the wind of the spring in between the end and the part that it overlaps. This separates the end of the spring and pops it out of the groove.
1 - 11 of 11 Posts
