You need a faster thumb.
How many miles do you have on it now ?Battery going bad, bad connections at the battery, frame ground, or starter connections, starter failing. Mine started acting up recently, I checked all of the above and then took it to the dealership for warranty starter replacement. Since then it cranks like new again.
97,000How many miles do you have on it now ?
Sent from my SM-G955U using Tapatalk
There has been a change in the part number for TS 111 starters from 4014058 (2014) to 4017209 (current). I understand this has to do with an improved seal which prevents engine oil from being forced back into the starter motor and gumming it up. I have long noticed a certain amount of oil mist/scum on the starter motor and surrounding engine case, the closest thing the bike has to an oil leak. My 5-year warranty on Chieftain #873 will expire in January; the up-dated starter is something I plan to put a claim in for before then.Hi there,
My 2014 Classic has come down with a case of starter lag. When I push my starter button there is an unusual pause before the starter kicks in. It doesn't happen every time, but just enough to be annoying. Would anyone have an idea what could cause this?
I had been noticing a lot of seepage buildup around the starter for quite a while before it started acting up. Now that it's been replaced I don't see any at all. I didn't really think much of it before, since the oil cooler and filter are right there and I figured I had an O-ring going bad. Looks like the starter was the main issue now.There has been a change in the part number for TS 111 starters from 4014058 (2014) to 4017209 (current). I understand this has to do with an improved seal which prevents engine oil from being forced back into the starter motor and gumming it up. I have long noticed a certain amount of oil mist/scum on the starter motor and surrounding engine case, the closest thing the bike has to an oil leak. My 5-year warranty on Chieftain #873 will expire in January; the up-dated starter is something I plan to put a claim in for before then.
--- Randall
Only about 15 thousand milesHow many miles do you have on it now ?
Thanks for that Randall. I am noticing the same thing you describe with my bike. I guess I will pursue a replacement starterThere has been a change in the part number for TS 111 starters from 4014058 (2014) to 4017209 (current). I understand this has to do with an improved seal which prevents engine oil from being forced back into the starter motor and gumming it up. I have long noticed a certain amount of oil mist/scum on the starter motor and surrounding engine case, the closest thing the bike has to an oil leak. My 5-year warranty on Chieftain #873 will expire in January; the up-dated starter is something I plan to put a claim in for before then.
--- Randall
