Ditto question on use of the flash card. I am looking for one to buy, as long as it has not been used, obviously. Thanks.I have a set of stage 2 cams with 331 miles of run time and I have the flash card and gasket. $300.00 includes shipping. Also have a gutted cat header with heat shields $125.00 includes shipping lower 48.
The stage 2 have the best sounding lopey idle and great linear power .When I had the cams installed the mechanic took everything out of the boxes and handed me back the card and gasket said he won’t be needing them because he would dyno tune with power commander. I went to 585 cams because I went with a 116 big bore kit again Dyno tuned with PV3 this time.Did you use the flash card? If so it can’t be used again. What did you think of the stage 2 cams?
ChromeBlack heat shields?
Are these cams still available?I have a set of stage 2 cams with 331 miles of run time and I have the flash card and gasket. $300.00 includes shipping. Also have a gutted cat header with heat shields $125.00 includes shipping lower 48.
The gutted cat fits a 2018 Springfield dark horse?
yesAre these cams still available?
I dont know if there is a differenceThe gutted cat fits a 2018 Springfield dark horse?
any idea on the difference and if they are interchangeable?cats go from 14 to 17 and 18 to 20
