I admit that removing the end from the mount is correct for putting on the new part, but is totally unnecessary to remove either rod end to adjust the shifter height unless you are replacing the shifter mechanism!
That is what you said to do to adjust the shifter!
This was to a guy that was not replacing his shifter mechanism.
The point I was trying to make is neither end of the adjustment rod needs to come off because one side is right threaded and other end is left threaded and by turning the rod they move in and out the same amount in each rod end, if one end is removed it will only run out the threads on the one end before it can get long enough to raise the shifter the proper amount!
That is what my warning to the guy was all about, Sorry we misunderstood each other.
Not talking face to face with each other sometimes does that and get misinterpreted! Hazards of the internet forums!
