Fork sleeves, fork wrap around blinkers, and headlight grille.
Thank you brotha, been spending a lot of time to get her where I want!That’s a mean looking scout you got there.
you’re so right. I think I have a problem now.But do you ever actually have her where you want? We can always find more we want to do.
They’re on my list to change for sure...Love that headlight grill.
The OEM pegs now stick out... go get some serrated angry pegs.
Thank you man, and yes I agree. Can’t have enough black.What did you use to wrap the front brake cables? Mine are chrome braided and id love to have them black like my clutch cabling.
P.S. Great looking bike !
edit: Nvm I see you have the chrome braided too. LOL
Anyone got ideas on this?
The grill was very easy to install, has an adhesive ring behind it that mounts on the outside of the original OEM headlight retainer ring. Unfortunately the place I got it was ordered all the way in Paris, from a company called tank machine. They are well know for having a load of aftermarket accessories, especially for the scout bobber.Where did you get the grill? Link? Was it difficult to install? Been looking for one.
@Barker_The_BobberWhat did you use to wrap the front brake cables? Mine are chrome braided and id love to have them black like my clutch cabling.
If it or any accessory light stays dim,all ya need to do is attach a small ground wire from the fender or the LED itself,to the frame.Problem solved.Does your fork led stay slightly dim when the bike is on?
There are 3 wires running of the LED fork blinker. One of them is a running light i believe, which i did not connect since the OEM blinkers dont run unless the blinkers are switched on.Eagle Lights Fork Turn Signals - Wrap Around - For 39MM - 60MM Fork TubesDoes your fork led stay slightly dim when the bike is on?
Hey marcus,The headlight grill look s great . Share where you got it. I think others would like to know.
I was gunna do the same, but the metal color actually appealed to me.I got my headlight grill from tank machine too. I just painted it blk.
