I’ve recently have undertaken to task of installing a new pair of K-Tech shocks on my Scout Bobber. In order to complete the install it appears I need to remove the top slip-on. I’ve unfastened what appears to be a tension fastener where the slip-on meets the header. I’ve also removed two other bolts that stabilize the mid and rear of the slip-on. The slip-on wiggles from the rear enough to know that it should be able to slip off. But I can get the damn exhaust to slide out of the header. I’ve managed to get it to pull back maybe a centimeter if that even.
Does anyone have any suggestion or tricks on how to loosen and remove that slip-on w/o damaging it? It seems to be caught in some way where the slip-on slides onto the header.
BTW, I’ve even had some pull on it w/ enough force to pull the slip-on with a nylon strap while I attempted to wiggle the exhaust loose. But again nothing... barely a centimeter.
