1 - 7 of 7 Posts
Gentlemen: On my SDH,at the bottom of my headlight,at the 6 o'clock position,there is a little hole or window which has a plug covering it from the inside or back of the assembly.What is that little window used for??I looked at my SM but can't find anything in there pertaining to that little window. It must be there for some reason,but obviously not used on my model.Just curious! Thank you!! Dummy Dave!!!
It's for optional light not offered by indian.
The scouts have same setup but sme scouts come w a light there and some dont.
Adding that light wont better your night vision at all
That little hole in the bottom of my headlight is only a half inch or so in diameter.So are you saying that it's used for a sensor to turn on other driving lights if so equipped?? Thank you again!! Dave!!!
1 - 7 of 7 Posts
