I just did a valve clearance check on my Scout. It’s a 2017 ABS model with 22k miles. I thought people may be interested in reading about it. I will say in advance that my bike has a loose right exhaust valve in the front cylinder that I am going to have adjusted by the dealer. The procedure was moderately difficult for me, a hobbyist mechanic at best; attempt at your own risk. Any comments or suggestions appreciated.
Materials and tools
bike lift+tiedowns, etc
A SERVICE MANUAL
hex and torx sockets
torx allen wrench or similar low profile tool
torque adapter
rubber mallet or wood block +hammer
various metric sockets to remove bolts, plus a 3” and 6” socket extension
one 22mm socket
Feeler gauge set
Replacement zip ties
two torque wrenches - most small bolts are 10-14NM, frame bolts are 30-35ft lbs. check your service manual for actual values
a headlamp
6 NEW valve cover isolators $11.xx each plus shipping from Indian Motorcycle
Before the valve covers can be accessed, the following parts must be removed:
Seat
Fuel tank- I disconnect the fuel rail to tank line at the fuel rail. you can see a demonstration of this here: Screaming Scout Intake installation
Both side frame rails, including cutting the zip ties
Factory air box or whatever you have there instead
plug coils
spark plugs
flywheel inspection cover removed
The cover for this is held in place by 2 allen bolts and has an o-ring seal between itself and the stator cover. it requires some wiggling to remove. Once it is off, the flywheel nut is visible as pictured. It is turned in the direction indicated to move the engine through its cycle manually
top view of rear valve cover
In this view I have already cut the zip tie holding the wiring harness where marked. I later removed the coolant overflow line where indicated. I also had to remove the fuel injector, directly in front of the valve cover, toward the front of the bike. Once the torx screws are removed from the valve cover, tap the cover on either side with a rubber mallet or equivalent to loosen it. this valve cover has very little space around it. I had to elevate the cover on alternating sides to remove the valve cover gasket. I was then able to remove the cover without risking damage to the gasket. It is removed toward the right side of the bike. inside the valve cover there is a spark plug tube seal, be sure to remove it.
rear cylinder, flywheel side
From the flywheel side, rotate engine counterclockwise until the pair of valves you want to measure have the lobes pointing straight up from the valve like pictured here, and in the service manual. Then use feeler gauges to measure clearance. Repeat for other pair of valves. Clean the valve cover mating surfaces and place the gasket back on the head, then replace the valve cover. The gasket has a central ridge that mates to a groove on the underside of the valve cover. Also, be sure to put the spark plug tube seal back. Make sure it stays in place while you are moving the cover and gasket around. Then, install the NEW valve isolators and torque to spec of service manual. Do not replace the spark plug yet.
Front cylinder
Removal of this valve cover is more difficult. I had to remove the right front valve cover bolt with a torx allen wrench due to lack of space between it and the frame. You could also use a low profile wrench, with some kind of torque wrench adapter. I also had to disconnect the radiator hose as pictured. No coolant was lost when doing this. I initially attempted to detach the thermostat housing, but that did not provide enough space. This valve cover came out to the left of the bike. Measuring the valve clearance is the same as for the rear cylinder. This was when I discovered the loose right exhaust valve, clearance 0.010-0.0105”(max is 0.009”). replacement of the valve cover is similar to the rear cover. Then reassemble the bike in the reverse order you took it apart,torquing to spec.
I hope this description was helpful. I am not a professional mechanic, so caveat emptor. I would appreciate feedback from anyone who notices an error, or has a better way of doing any of the tasks described here. Also, any suggestions for torque adapters for these hard to reach areas would be appreciated.
Main takeaway: check your valves!
Materials and tools
A SERVICE MANUAL
torque adapter
one 22mm socket
Feeler gauge set
a headlamp
Seat
plug coils
spark plugs
Front cylinder
