1 - 7 of 7 Posts
Hey Bobbers,
I have a 2019 scout bobber ABS. I recently did the following projects
1. Replaced the stock handle bars: Got FMB choppers mini ape handlebars. Got extension cables to fit the length, connected new cables to ABS module, drained the fluids and got the brakes back.
2. Replaced stock air filter with Trask performance air filter TM8000.
All this needed me to disconnect battery and fuel tank. After installation of the above, my motorcycle is not starting. The battery is charged and the ignition is turning ON. The engine tries to come to life, but does not.
I checked the console, I get the chk engine error. Any ideas to resolve this? Is there a engine reset procedure?
598860
598861
Post #13 on this thread says you pull in the trigger and hold it for the error code to show. That should tell you what's wrong.
And there's a phone app called Indian Diagnostics that lists the codes when you put in the number.
Care to share with the rest of the class? ;) What was it??
1 - 7 of 7 Posts
