1 - 19 of 19 Posts
WTF?!?
The US bobbers’ license plate bracket lower holes do not line up with the plates’....
....prompting the need for me to replace it or fabricate a vertical mount that is more “clean”
Thoughts? Comments?
WTF?!?
Thoughts? Comments?
They do line up. However I modified it for vertical mount.
Sent from my Pixel using Tapatalk
I want to go fast.
WTF?!?
Thoughts? Comments?
WTF?!?! NYS Can’t even make license plates right?
You got me, I’ve seen Bobbers sporting plates from TN, GA, AL, FL, LA, TX, CA, MD, VA... plus the many on this forum, and you’re the first complaint I’ve heard.
Discussion Starter #4
Horrible first pic of lower right corner. You can only just make out the hole in bracket. Second pic is from rear.
Figures Ny state strikes again...
Discussion Starter #7
Okay so Ive finished my mod. Total spent < $40 including a new license plate bracket as I wanted to keep an original part un-altered. I love the way it came out. Definately inspired by bia9977 above so thanks for that. I hope you like it.
Laws vary from state to state, but most do require that the license plate be illuminated. Using one of the radius tag frames with LEDs from Custom Dynamics will get that requirement met. LED tag bolts will also do the trick.
I did the exact same thing. I took a cheap hacksaw to it since it’s just plastic. The project took less than 2 minutes and it makes the whole bike look so much more sleek.
1 - 19 of 19 Posts
