there is no patent or other restriction keeping Andrews or other from making replacement cams without that specific type of centrifugal compression release. There are several other type of cent. comp. releases that are fair game. However, it may be possible for the Andrews cams to work without a comp release. How? When comparing cams the first number pro-engine builders, like myself, look at is the intake valve close degrees. Why? because when cranking (and running) the engine doesn't make compression until the intake valve closes. The closer to BDC the intake valve closes, the more dynamic / cranking compression the engine will have. The stock cam closes at 30° ABDC, leaving 150° of piston motion to create compression. The Andrews closes at 36° ABDC, leaving 144° piston motion to make compression; so the engine will have slightly less cranking compression.
The intake valve close timing also effects the torque curve, and HP limit. Earlier int vlv closing (Fewer degrees ABDC) makes more TQ over a wide low to mid rpm range; but it also limits the engine volumetric efficiency at higher rpms, where the TQ & HP fade, with the effect on HP being greater. A 6° later int. vlv closing will typically shift the torque curve 150-200rpm higher, with low rpm TQ being less, while high rpm TQ & HP being greater.
Adding a bit extra lift helps offset the effect of an early intake closing, but there is a limit due to mechanical stresses within the valve train. Another trick we use when designing a cam is to alter the cam's profile, to increase lobe intensity. Lobe Intensity measures the acceleration / decel of the valve during the initial opening and closing. Again, mechanical stress limits how fast we can open or close the valve.
By delaying the intake valve closing 6° the cranking compression is reduced by approx 0.5:1, which may be enough to eliminate the need for a compression release for starting.
respects,
Tom - AMS-HyLift Lifters
