Battery tender makes a harness you can run directly from the battery, so it's always on. I routed mine through the tank wiring tunnel.
You can use a car charger or a USB terminal at that point. It's all available through auto parts stores or at J&P cycle.
For phone charging, I now use a small pad charger mounted to an X ram. I routed the charger cable to the dash pocket cable and it's charging when the bikes on. I still keep the battery tender setup in place as a backup.
Hi luvdgl. I would like to have a non switched USB cable in that compartment. Any suggestions?
